#312409 07/08/14 10:30 AM
Will a Stromberg 97 carburetor fit my 235 CU engine ?
Markings on the carb.
P19400 - 19
EE-1
Will this be at good setup ?
Michael
Indian351 #312433 07/08/14 01:50 PM
It might make it run like a V8.
Joined VCCA June 1, 1961
Indian351 #319494 09/25/14 11:57 PM
I once used a Stromberg 94 on a 216. It has the correct vacuum advance connection. You may need an adaptor because you are going from a single barrel to 2 barrel. It was the best carburetor I have ever had and I could whip any 216 Chevy in accelertion.
