#311158 06/24/14 03:33 AM
can someone out there tell me the size for the parking light bulbs on my 35 standard..??[front?]...and where to get em in aust???..QLD??
..........thanks..dave..........
Dave,
if it is still 6 volt , then try your local motor cycle shop..
Peter
It should be a #63 bulb.
You should be able to order the #63 bulbs from your local auto parts store or you can order them from the Filling Station in Lebanon, Oregon USA. www.fillingstation.com
There are two sizes used on Canadian based headlights. One is the normal #63 which has a base width of app. 9/16 and a smaller one with a base width of 3/8. The smaller ones are harder to find but often turn up at swapmeets.
thanks for all that info and ideas...i doubt that if anyone over here in a parts shop would know wot a #63 globe is?? I dunno..I am sure its a little 3/8th one...but again...not many here would know wot 3/8th is either...LOL..so i think i will just take the light bucket into a bike shop..and start from there..thanks..
.dave.
i just relized 345chevy is local to me...so a "no63" globe is a universal size...??? thanks...dave....
You won't know until you go down to the parts house and ask. If they can't get a #63 bulb, you can still order one on the Internet from places like the Filling Station. www.fillingstation.com
In 40 odd years on the spanners here in Aus I have not heard of globes by the numbers you US boys use. I must admit I havent used 6 volt globes for years as I generally need 12v and occassionally 24v.
yes,, the filling station has those globes at $1.25ea..but i'd rather get em now than wait a week..for delivery..[which is exellent]and all the other stuff i have to do to get em
so tomorow I going armed with me bucket...and see wot i get..
i am also looking for "something" to replace the cork "gasket" that the glass sits on ....what do you guys replace that with??
....thanks dave ....
..so i got 3 from a local yamaha dealer marked as "3w 3v e13"
about 8 mm wide or 5/16??i got these two weeks odd ago..
late post ,but they r in and work thanks dave
[Linked Image from i57.tinypic.com]
AMS Offline
This is also the correct bulb for the tail lights, right (my car is a 34 master)?
Thanks.
AMS #376988 10/16/16 12:07 PM
the 3 candle power #63 was the correct tail lamp bulb for all years that had a two bulb thail light. I would recommend going to a 6 candle power #81 bulb which is the same size,
The brake light bulb was a 15 C.P. #87 and I refitted the lamp with a 21 CP #1129.
The ultimate is the LED filled lens that is sold by the Filling Staton. Very expensive and SUPER bright.
AMS Offline
Thanks!
AMS #377001 10/16/16 03:43 PM
Super bright is important these days as there is so much other light in the city at night. Dad was stopped by the cops with his 6 volt system because they thought his tail light was out. Then when they looked they would change there mind...lighted streets! Before the 1960's streets and roadways were not lit at night and 6 volt systems were real bright. I can well remember those days. Good luck with your bulbs.
tail light brake or running bulbs. in this case you want to have the brightest lights back there you can.
I bought ron francis wireworks , BRITE BULBS B-1005 I believe. Much more candle power than stock.
Another un-thought of problem is DARK RED GLASS. You want a lighter red glass for running and brakes. just hold the lens up to the light and look at it.
You might also want to consider Harley Davidson motorcycle dresser , accessory tail lights, they look like stock 1932-1935 cowl lights. Mount them to top bolt on your luggage rack to only come on when brake pedal is pushed .
mike lynch
wizard
Brand new Indian Royal Enfields still use them. I bought a packet from my local dealer. Cheap as chips and smelled faintly of curry.
ColinGrant
