dbraham Offline OP
Does anyone know were I can purchase Brackets that hold the Vacuum Advance Unit and the Distributor to the Engine Block.
I have quite a number of Distributors with either no brackets or the Vacuum Unit and no Bracket, but don't have the Bracket that mounts on the Housing between the Vacuum Unit Bracket and the Distributor it's self.
I have Mounting Brackets for late 1940's and early 1950's, but these are not suitable for the earlier 1938 to 1945 Vacuum Units.
The clamp the is bolted to the block with one bolt and clamps around the distributor is the same from 1939-1957.
The 1938 is different and bolts to the block with two bolts if I remember correctly.
