I am reinstalling my intake and exhaust manifold and want to know if there is a correct torque spec for bolts?
Chevrolet did not publish torque figures til the 1950's. At that time they suggested 15 to 20 foot pounds for the 216-235 engines. No reason it would not apply to the 194.
No torque specs. were used back in that era. You can get a modern chart and look up the size and grade of the bolts for the proper torque specs.
By the way, the 1929-32 engines were 194 cubic inches, not 192 cubic inches.
Good luck with your project!
Yeah no Torque Specs from Chevrolet . . .
I found several sources of info based on the Criteria JYDog Listed Above:
What is the Proper Torque to Use on a Given Bolt?by Industrial Fastener Institute
Torque-Tension Relationshipby Fastenal
Torque Specifications for Early Vehiclesby The Filling Station
All good reference Information for Fasteners
