#310686 06/17/14 12:16 PM
Tu papa Offline OP
For my 29 my radiator cap; it is stuck in place. Everything is clean and new, and not cross threaded. Any ideas how to get this off, without beating up my chrome? Thanks for the help.
David Nittler
try using a pipe strap tool the one that won`t mark up chrome piping.
Tu papa Offline OP
Dumb question, where do I find these? It the strap leather or metal? Thanks
David Nittler
Harbor freight or a good hardware/ plumbing supply they are called strap wrench and are made of a rubber type material.
Al
Pipe strap tools are extremely common. You should find one at any hardware or tool store.
You might even try a kitchen supply store. Ask for something for helping to remove tight jar lids.
First, spray it with some penetrating oil and let it soak in for a while. I use PB Blaster, but folks say that the best is AFT and Acetone 50/50.
Then, you could wrap the cap with an old bicycle inner tube (to protect the chrome) and then use a large pipe wrench to loosen it.
I use one of those oil filter wrenches with the lever action handle. The smaller one fits those caps and the metal band is soft enough to indent so it really grabs well. Doesn't harm the chrome a bit. Those rubber band wrenches might work but the rubber stretches so the grab might not be enough.
Tu papa Offline OP
Thanks one and all
David Nittler
When I installed my new radiator, I didn't remove the paint from the threads of the radiator. I could not get the cap off. I did what Chipper said and it worked great. I cleaned the threads on the cap and the radiator and it works fine
Or you can use basic physics and expand the cap. Protect the hood paint with some plastic sheets, and pour very hot water (almost boiling) on the cap to expand it. Do the pour slowly. The cap will be very hot, so use a towel or a strap tool to grab and twist the cap.
Don H
Tu papa Offline OP
I got it loose. Thanks
David Nittler
Awesome . . .
Main reason why I love the gang here, plenty of USEFUL Ideas/ Methods !!
Tu papa Offline OP
That is for sure they are all a big help.
David Nittler
