Hi gang, I need someone to decode this serial number and label the parts for any serial number. Talking 1964 41867L166773 The 1867 denotes a Convertible........Don't know the rest. I would like to know where the serial number is located on a 1964.
4 = year 08 = Corvette 67 = convertible S = StLouis last six numbers assembly sequence
serial number plate welded to the right side hinge pillar cross brace under the glove box.
I know the numbers don't agree with yours so don't shoot the messenger.
So in my example (taken off a 64 Convertible) it should be 4 = 1964, 1867 = Convertible, L = (?), and X # left over for the sequence #?
Yes, I can't explain that. What I listed is what my material listed. We will see what happens from here.
Posts: 845 |
L is Los Angles. S would be St.Louis. Unsure what the 08 means but it can't be Corvette because they were never made in Los Angles.
Posts: 295 |
Hi gang, I need someone to decode this serial number and label the parts for any serial number. Talking 1964 41867L166773 The 1867 denotes a Convertible........Don't know the rest. I would like to know where the serial number is located on a 1964.  I'm not sure where the "08" reference came from in this thread, but that VIN is from a 1964 Impala convertible (non-SS) built at Los Angeles. It was the 66,773rd full size 1964 Chevy built there. The parts of it are: 4 = 1964 18 = Impala V8 67 = convertible L = Los Angeles 166773 = the sequential vehicle number beginning with 100001 The VIN plate is in the driver's door jam. Verne
That is the answer I wanted. Many THANKS!
For some strange reason I thought you said it was a Corvette and the numbers I looked up pertain to a Vette.
