I have a 1931 2 Door Sedan with the following tags. Can someone assist with detailing these numbers.
Floor Board Tag 3AE67942
Fisher Body Tag
Job No: 31551
Body No: S 25483
Trim No: 1
Paint No: 72
The 3 indicated it was built in St Louis
AE indicates it is an INDEPENDANCE Model. All 31s are AE
# 31551 indicates it is a two door coach
The following is taken from Chevrolet Duco Color Specifications
Paint 72 = Hood Serge Blue Duco 2466868
Hood Moulding Black
Hood Stripe Cream Medium V.E.P. 2154
Body-Upper Black
Body Lower Serge Blue
Body Mouldings Black
Body Moulding Stripe Cream Medium
Front Pillar Cover Serge Blue
Instrument Panel Black
Inst. Panel Depression Serge Blue
Sunshade Panel Black
Window Offsets Serbe Blue
I hope this helps you.
Joined VCCA June 1, 1961
Thank, Car is color correct based on this. What is correct interior cloth color it is gray now.
3AE67942 indicates that your car was the 57,942nd car made in the St. Louis factory in 1931. (Note: Car serial numbers started at 1001).
S 25483 dictates that your car was 25,483rd coach made in the St. Louis factory in 1931.
Hi
Yes it is grey.
Grey plush upholstery with cotton velvet liner.
Brian
