37ryan Offline OP
Need to know what type of lube and how much is used to lube the brass bushing that is pressed into the end of the crankshaft and accepts the xmission input shaft. The engine is a '61 261 6 with a three speed manual. Thanks in advance for your thoughts
A thin coating of wheel bearing grease.
