I would like to borrow or buy rear spring lubricating clamp J-595. Thanks
Larry,This is how I pack the rear springs on my cars.Jack up so wheels "hang"Get a 1/4 inch (small thread) grease fitting.Drill present hole to the next drill size larger.Drill thru inner canvas lining so grease gets to inside spring .Thread fitting in hole,If you have an 1/4 pipe tap it works better.Fill up your grease gun and start pumping.I drill a second hole about 1/2 way between the present hole and the rear of the cover so more grease gets to the rear of the spring where most of the flexing is.I used to borrow a clamp as shown in manual but this works just as well.It will NOT use a full tube of grease.Keep cardboard under springs for a few days as they will leak out some of the grease.
Gene, Thanks for the input on lubricating rear springs. I'll give it a try. Do you leave the grease fittings installed both aft & forward of the axle.
Larry, I would suggest pulling the grease nipple out. It realy not a big deal but if they get snagged on some thing and pulled out it will make a hole larger than the replacement nipple will fit. It shouldn't be any inconvieniance as I see it. You so seldom have to grease the springs.
Larry, I was out touring for the past week.Just thread fitting in ,grease, then remove and screw into next hole.Some grease will ooze out but this happens when clamp is used also.
