#30831 09/07/02 02:54 PM
I can access the 2 lower bushings but how do I get to the 2 upper bushings? Do I pull the pitman arm or is there an easier better way? Thanks.
Larry, The pitman arm is in two pieces,the lower half will is removed by pulling it off (down) and the the top bushings will be exposed.
not necessary to remove top half.
Gene, According to the shop manual the pitman arm is built-up assembly. The pitman arm proper is a heavy forging machined to receive 4 tapered rubber bushings. The plate to which the tie rod balls are bolted has 2 studs which pass thru the rubber bushings in the pitman arm. A retainer plate completes the assembly.
Hi Larry,
Assuming you have removed the two nuts and washers this should allow you to remove the bushing retainer. Now you should be able to separate the pitman arm assembly in order to install two bushings from the bottom and the remaining bushings from the top. Then replace the bushing retainer, washers, and nuts.
Agrin
I think that I may have confused Larry.The heavy forging that is attached to the pitman shaft is the LOWER half and when unbolted pry up on the half that is attached to the tie rod ends.That is also the half that have the studs pressed in.(upper half)The bushings were used to absorb road shock but when they go bad play in the steering is the result.The two halves may have grown together so a LITTLE force may be necessary.
Gene, Thanks for more info. It looks to me that there is not enough clearance between the upper plate and the gear box to get the studs out of the upper bushings. Do I have to rotate the shaft to get clearance or do the studs come out at an angle? It would've been a lot easier if they used bolts with the nuts on top!
Hi Larry,
Try moving the steering wheel in order to reposition the Pitman Arm Assembly. Normally, this is a straight forward operation. There will be a position that the top portion can be lifted up in order to install the two top bushings.
Wish you luck.
Agrin
Larry,
Thanks to ChevNut's help, I just replaced the 4 Pitman Arm bushings in my 1940 Chev.
I found, after much expended effort, that the easiest way to get all the old bushings out is to remove the Pitman Arm from the shaft.
DocB
