#307562 05/06/14 06:00 PM
Can someone tell me where I begin investigating my mechanical brakes briefly locking up intermittently when I step on the pedal?
NEWSFLASH: You guys might enjoy this one. I went to a small car show this weekend and the winner of the most "original" car was a 2011 Camaro! Yes 2011. You can only imagine the response from all who attended.
If it were mine the first thing I would do is sand the linings and drums. There may be a glaze built up on the surfaces. Wear a breathing mask due to possible asbestos dust.
Chev Nut #307567 05/06/14 06:51 PM
I agree with the sanding recommendation, but I'd just do the drums first and see what happens.
The previous owner of my '28 painted the inside of the brake drums, causing intermittent grabbing. After I sanded the paint off, the brakes worked much better.
Thank you. 220 paper? I never removed the drums before.
220 is fine but do the drum and lining as it is easier than pulling the drums twice.....also pack the front wheel bearings if you never had the drums off......if any lining is left.
Chev Nut #307660 05/08/14 01:45 AM
While the drums are off use a can of BRAKECLEAN and make sure there is no grease or fingerprints on the braking surfaces. Locking up usually happens when there are contaminants on the linings.
J Franklin
much appreciated
Don't you have to pull the axels to get to the rear drums?
1938 Chevy One Ton Truck
1938 Suburban Carryall
1962 Corvair Monza Wagon
Member # 50,000
take whomever was running the show and or selecting awards and have them fill out the I Q TEST. stupid . Then in front of everybody grill the moron with questions as to their mental capacity.
I mean that is so stupid ,a 2011 camero as most original car.
The real question is, WHY is a 2011 camero in the show ??????
I am laughing so hard it hurts. mad
mike Agrin
Yes you do , just done the very same job, its a tricky job lying on your back under the car,so recommend that you find a hoist and do the job standing up, and small, long fingers are a definite advantage....good luck whip
Peter
never give 100% unless you are giving blood.
blueyAU #307972 05/12/14 09:29 PM
Next rainy weekend I will tackle it. Thanks for the heads up on the lift.
Joe
