Posts: 220 |
Good Day Everyone I am having new side windows made for my 32 coupe. Problem is I don't have an original pattern. I don't know the distance from the top of the sash channel to the bottom of the window opening when the glass is all the way up? This is important because this dimension will locate the small rubber seal that goes on the shah channel. And it will determine if the body nails can be seen when the window is all the way up. Bye for now. Mike
Posts: 220 |
Good Day My 1932 five window coupes job number is 32567. Hope this helps. Bye for now
