My 1931 has a Carter RJH-08 carburetor. It wants to run way too rich at idle. The low speed jet (idle tube)is definitely there but has no threaded,slotted screw on the end. Posts by knowledgeable people here suggest that the low speed idle tube should have a slotted screw attached (soldered?) to it.
The Filling Station lists a low speed jet tube, part # RW-466A for $18.50, which as pictured shows no slotted screw on the end. Another vendor, Gary Wallace at early Chevrolet parts lists variously: 1.A low speed jet tube with slotted screw as a package for $34. 2.A cap for low speed jet tube for $18. 3.A low speed jet tube for $18.
I am a bit confused. Assuming can be risky I know but I'm assuming a possibility for my rich idle is the lack of the slotted screw. But; the FS part appears to have no slotted screw and another vendor seems to sell tubes and screws individually or as a package. Any help/suggestion is welcomed.
Best Regards,
Tom
