akdale Offline OP
Where does the bracket go exactly?
Probably inside the fender secured with a fender to body bolt?
Which one?
Thanks,
Dale
Not sure what brackets you are talking about, but I have no interior currently so I can get you photos if needed...
These are from the inside:
Inside Rear 1
Inside Rear 2
Inside Rear 3
Inside Rear 4
BF315, all of your reference files have same set of 20+ pics. I think the bracket/brace he is asking about is o outside of car, within fenderwell, may be the curved 1/8" thick steel brace about 3" long, profile to match that of fender, which goes at topmost inner fender bolt instead of a standard fender washer, and helps prevent fender from sagging and pulling away from welting. I have these on my '31, assume '29 may be same.
akdale Offline OP
Thank you Sir-- Exactly the info I was looking for.
Thanks for the response 315. Great pics for reference.
