Posts: 135 |
Hello, I'm looking to replace the differential gasket on my 34' Master Town Sedan. Is it the same as the Standard? Does anyone have a part number or reliable source to get one?
Thanks,
Russ
Posts: 885 |
I agree with Mr. D in above post, but if you want a custom made one, you can go to The Filling Station and order part #G9012E. This fits 33-36 Standard (CC,DC,ED,FC) differential cover gasket. Is this what you need or is it the differential carrier gasket you need which carries a different number??
Jim.
The Standard gasket is different because the cover is smaller. The Standard gasket does fit 1937-1954 passenger cars.
Posts: 135 |
Thanks for the responses. Yes, I'm looking for the cover gasket and not the carrier gasket. I should have made that more clear. I think it's been a while since the oil has been changed and I'd like to get a look at things so the plan it to take the cover off.
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
Well the title is differential cover gasket so I don't know how you could have made it "more clear".
