#306658 04/25/14 11:40 AM
n2chev Offline OP
I have recently installed a rear back-up light on my 1948 Sport Coupe and need to know how it is supposed to be wired into the harness.
hoppy
"Four-Doors-Forever"
n2chev #306663 04/25/14 12:53 PM
It doesn't wire to the "harness"...You must have one of several contraptions that are on the steering column under the hood that a wire will hook to...and run it back...Or go with a "toggle" switch under your dash...Just don't forget to turn it off... laugh
I have several of these things...Some use a wire...Some are hooked the the linkage...You can find them on eBay...I'm still not sure which one I'm gonna run with...
kevin47 #306675 04/25/14 03:12 PM
The back-up light was not standard equipment therefore was not a part of the original harness nor was there a provision it. Since it was an accessory, wire, switch and the actual unit needed to be added/installed. see the following:
http://www.1948chevy.com/images-acc/bck-up.jpg
Johnny Johnson
VCCA# 33448
www.1948chevy.com
conv48 #306739 04/26/14 05:21 PM
n2chev Offline OP
Thanks Kevin-Johnny I think I will be using a (ACC) accessory switch that gets mounted under the dash to the left of the steering column next to the HEAT/FOG/DEF.
hoppy
