#30650 03/23/02 11:50 AM
ITSA47 Offline OP
I have a 47 stylemaster in need of one coil spring.
I am wondering the best way to go about matching the one I have. Or just replace both.
If I replace both, should I go new or used?
If used, is there a easy way to match up coils for fit and ride?
:confused:
#30651 03/23/02 06:46 PM
ITSA47,
I have a 47 Fleetmaster, and I would definetly replace both at the same time. You may have a problem just replacing one. One side will have the strong new coil, and the other side will stay where it is. I replaced both of mine at the same time with a pair from chevs of the 40s as mine was leaning to one side. The fit great, and brought the ride height back up perfectly.
I think they were around $110.00 for the pair.
part# 3694612
"Heaven is Driving my 47"
With that "GOOD GULF" gasoline.
http://www.gulfhistory.org/?
#30652 03/24/02 07:58 PM
Itsa 47
I have a few pairs of NOS coil springs if you are interesred.
chevyb
