Last year I bought a 35 half ton Chevy pu. It has an amateur restoration but looked and ran very good. The man I bought it from said the man he bought it from got it from an estate sale and had been told the engine had been recently rebuilt and not driven enough to be broke in yet. How true that is I have no idea but the engine ran very well.
I could not say the same for the steering however. It had about 6" of play. So of course I decided to repair that. I started with the steering gear box.
While waiting on parts a friend asked if he could hear it run. It wouldn't start w/o putting a little fuel in the carb. That was odd as it had always started right up with no problems whatsoever. A quick check showed the fuel pump was not working. Not a problem.
Eventually I got it running and the steering gear box rebuilt. There was still some play (about 2 or 2 1/2") in the wheel but not as much as before so I'll have to check the linkage. Just the same I took it for a short ride to town, about 10 miles.
3 1/2 miles down the road is starts running very rough. About 2 miles from town the temp gauge had climbed higher than I liked so I pulled over and let it cool down. Once in town I let it cool enough to check everything out. It still had plenty of water and there were no leaks. I tried adjusting the carb but got no where fast. So back home I went stopping once to allow it to cool enough to complete the trip.
There was no adjusting the carb. Compression was good through all cylinders, about 85+/-3. Timing was good. Points, rotor, etc all good. It didn't have a thermostat so I put in a 160* one and that didn't help either. So I gave the carb to someone here to rebuild. It was running very lean. I had to pull the choke out almost all the way to get it to idle halfway smoothly so perhaps that caused it to over heat.
Meanwhile I replaced the water pump just to be sure. The old one looks to be fine.
Before starting it again I decided to replace the old steel fuel line. I did that this week. The gas gauge was not working properly so I ordered a new fuel gauge sending unit hoping that will correct that problem. If not at least I'll have a new one installed. Until then I cannot start the truck as the gas tank is removed.
This truck has not been garaged. I only have room for one vehicle in my garage and it is filled by my 26 roadster. The truck has been sitting out front on the lawn several feet away from the driveway. It was safe, or so I thought.
Two days ago I saw that someone had hit the right front fender causing a dent 12" across and 2" deep.
I am not happy.
[img:left]
[/img]
So, now along with the steering problems and over heating problems and running rough I also have body work to do. Methinks I should also build another garage.
This is a pre-dent picture.
[img:left]
[/img]
