#305174 04/07/14 07:57 AM
I an trying to find out what works best. on my 30 coupe, it seems I will have to replace the radiator. I have no plans of showing the car. Nice weekend rides with my wife is what I am looking for. My question is, should I replace with a honeycome radiator or use a modern core. Local shop says he can do the job using my top and bottom tank and mounting brackets for $500. Should I go this route or is there a good place to but a complete radiator from such as Brass Works. Will the modern core give much added cooling?
Cottontop #305186 04/07/14 09:35 AM
From what you describe and your needs I think the modern core would be fine. I don't know about increased cooling, but I think the honeycomb core is now around $1000.00 without installation labor. A friend just had his 32 recored locally with a modern core and it was about the same price you quoted.
m006840 #305187 04/07/14 09:59 AM
I replaced the honeycomb in our 29 with a three core modern one. I changed the tanks myself and it cost $150. It works fine but I had to use a thermostat as it ran to cold.
a3alf #305206 04/07/14 05:05 PM
Cottontop--I replaced the honeycomb core with a modern 3 core in 2003 and have driven my 31 several thousand miles and have never once experienced over heating.
hoppy
"Four-Doors-Forever"
n2chev #305245 04/08/14 07:25 AM
Is there another place other than Brass Works to buy a complete radiator?
Cottontop #305348 04/09/14 08:59 PM
Most radiator shops can put your tanks on a new core.
Al
a3alf #306363 04/22/14 12:37 AM
[bleeped] Right!!!
hoppy
Cottontop #310569 06/16/14 08:15 AM
Well, after trying a number of things, I put in a new radiator and a new waterpump. The car runs cooler than it ever did. I should have done this to start with.
Cottontop #310577 06/16/14 10:39 AM
Yep. Those two items will sure make a difference in the cooling system.
Cottontop #310600 06/16/14 03:52 PM
That is great, but with the NEW radiator was that a new Honeycomb Original Style or a new recore Radiator Modern Style ??
Completely new radiator, modern style, from Brassworks. I am not into showing the car. I just want good functionality when my wife and I go for rides. Not having to always worry about overheating is great.
Cottontop #310672 06/17/14 08:10 AM
Nothing wrong with that...
Are you Happy with the Quality and the look ?? Do you have any picts would like to see what it looks like !!
i for one just couldn`t do a modern core in my 30.
having spent over 4k on the front end of my car what with new honeycomb rad. new motometer,wings and rad cap fog lights and rechrome work. to me its the frist thing people see when i`m going the road. i just had to do a honeycomb.
buggymangp #310679 06/17/14 10:36 AM
I am happy with the quality and the look. The quality and craftsmanship by Brassworks is great.
As far as getting the honeycome replacement, I guess that is up to the individual.
Cottontop #310749 06/18/14 05:11 AM
Get yourself a aftermarket stone guard and the stikky beaks will have to look in to see it.
I fooled around with a honeycomb radiater that I had made new for my '31 resto, only to find that their tooling was worn out which left very little room for water, that worked OK on the flat but was a shocker on hills, with my modern core the guage never moves once it gets to normal.
Brian
lachlan31 #310752 06/18/14 07:45 AM
I do have a stone guard and from just a few feet away you can't tell the difference. On the couple of rides we have taken so far the temp. gauge just barely got to the normal range. I am very pleased with everything so far.
Cottontop #311086 06/23/14 08:17 AM
Took a 50 mile ride yesterday. Car ran cooler than it ever did. Temp. gauge right on the line between cold and normal. Might just be me, but the engine even soulded better.
