Can I get suggestion on removal and re-installation procedure on the harmonic balancer/flywheel....,thanks
There are specific installation tools for each operation, both designed to correctly remove and re-install the balancer onto the crankshaft snout.
The puller makes easy work of pulling the balancer off.
The installer is basically a bolt with large washer and a threaded nut same size as the threads that easily pushes the balancer back on without resorting to whacking the balancer with anything. Whacking it is the wrong thing to do. If you shop arpound at automotive parts stores you should be able to purchase the pair. If not shop ebay.
Its always nice to have the right tools in your collection.
mike
