#304565 03/30/14 02:46 PM
Now Men I have another question: Has anybody replaced the dash speaker above the glove box? I'm replacing the one in the 63 impala ss NOW The Gerry rig job someone did 2 3.5 speakers were wired to the speaker grill I ordered a new speaker from classic radio and I only have 1 bracket to bolt to can someone tell me where to bolt the other end? 1 end of the bracket is a little longer than the other. As before any help would be greatly appreciated and thanks in advance men.
Wilwood Engineering1955-1957
The correct speaker is a 6X9 10 Ohm. It is held in by a special bracket that lays on a ledge in the front and has a single bolt to hold the free end. The the special bracket is unique to the 63/64 cars.
PS: A special note to all members. Never - Never dispose of a speaker frame that is an original speaker. Many are unique and can be reconed and operate as new.
Agrin devil
follow ray's advice. i've sent ray several original corvette speakers for re-coning and his work is excellent and reasonable.mike
Thanks a million Antique Mechanic that was my thought also but I wanted to verify I really appreciate the help. You have a great life and again thanks!!
Just wanted to let everyone know put my speaker in added some inside insulation works great. Thanks to all!! I have 2 other questions 1 What size speaker goes between the back seat where the chevy grill is mounted? and 2 Does anyone know where to get the lock ring for for the ss inserts on the hub caps? Thanks again guys
