The serial number of 1BA0417332 indicates that the car was built in the Flint factory. It is a series BA manufactured in April of 1932 and the vehicle was the 16,332nd car built in the Flint factory in 1932. (Note that the serial numbers started at 1,001).
The Fisher Body cowl plate breaks down as follows:
Job No 32568 = 1932 Cabriolet
Body No N 91 = Built at the Norwood, Ohio factory and the car was the 91st cabriolet built in that factory in 1932.
Trim No 19 = Genuine Tan Spanish Grain leather interior with imitation Tan Spanish Grain leather on the side panels. The top was Tan Teal.
Paint No 106 = The vehicle was black with either Aurora Red or black wire wheels. The door belt insert was Aurora Red and the body moulding stripe was also Aurora Red as well.
Now, here is the confusion. The car serial number plate indicates that the car was made in Flint. However, the Fisher Body cowl plate dictates that the car was made in Norwood. Possibly, either the cowl tag or the car serial number plate might have been changed. If the Fisher Body cowl plate is still riveted to the cowl with factory rivets then, most likely, the car serial number plate was changed since it was originally attached to the wood main sill with small nails. Also, the body made in Norwood could have been shipped to Flint and assembled to the chassis in that factory instead. However, the Fisher Body cowl tag and the car serial number factory designation codes usually match.
