Posts: 108 |
I will need to install a heater that really puts out well as my 29 Sedan will be driven in sub-zero temps. Just checking to see what I have missed in my www search. I am sure that the heater needs to put out 12,000 BTU or more. I intend on sealing all the air leaks as I am putting the car together. Thanks, Dale
Posts: 1,966 |
You may want to consider insulating all the exterior panels and the roof as well before you put in the headliner, lots of suitable products available I think. I have a heater I took from my '31 Coach which I don't plan to use here in the Maritimes, I'm assuming it is plenty. You don't want something with too high output or it will be very uncomfortable for the passenger.
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
Insulating the panels etc. is an excellent idea. I believe that there was an article about Steve Kassis 32 in the G&D and it included photos of the insulation he added, though his concern was more for sound insulation. You can contact Steve Kassis thru the Filling Station.
Posts: 108 |
I do plan on insulating before I finish the inside. Still not sure what to use though. I don't like the idea of sticking materials directly to the inside of the sheet metal. I fear that the insulation will trap moisture and cause rust. I am leaning toward taping foil clad bubble wrap behind the upholstery panels.
Posts: 108 |
You don't want something with too high output or it will be very uncomfortable for the passenger. Good point. But I would rather have too much heat than not enough. Fan speed and water flow control will help. Dale
