whitmoy Offline OP
I need to replace the driver's side rear quarter glass in my 30 4 door sedan. Wondering if anyone can recommend a glass supplier ?
Most any good glass company will be able to cut one for you with the old glass as a sample.
Does anyone know if the rear quarter glass is the same on the '31 four door as the '30? If so I'll be able to let the gentleman use mine as a pattern for the glass shop to make his. We live only about 25mi apart.
Best Regards,
Tom
My parts book lists two different part numbers.
