Posts: 6,689 Likes: 21
Posts: 6,689 Likes: 21 |
I replaced the vacuum shift tank and piston, etc., on the 41 coupe today. (NOS unit still in the box which I was saving for the 41 project. But, alas, the coupe needed it right now.) It had protective rubber plugs in the orifices. The lip broke off the main one receiving vacuum from the engine (the other is to the frame filter) and as I tried to fiddle it out with a thin screwdriver but it just got pushed farther and farther in. Way down to the curve. Just could see it. Not good. Couldn't blow it out, either. Shucks. Anyone have any idea how I got it out? What would you do. Charlie
Posts: 388 |
Could you push a small vacuum hose in the pipe and hook vac hose to a running engine to supply vacuum ?and suck it out? or is it really jammed in tight?
Mel, That is exactly what I did. I didn't think it would work but it did. I hooked the vacuum line up to the cylinder and then to the engine as normal and then started the engine. I then took it back loose and looked in the oriface. No plug. Whee! I don't have a clue as to whether it went to a cylinder or our the exhaust or what. It wasn't in the metal line or the hose. Just gone. You have a good mind and we think alike. Thanks for your response. Next time I have a problem, I'll know who to call. Best, Charlie
Posts: 2,306 |
Hi Charlie, I worried all through supper about your problem. Since a picture is worth a thousand words I came up with this solution. I figured if the vacuum cleaner didn't work then get rid of the sissy vacuum assist. Time to drive a stick like a real man. For $75 I will sell you new linkage... It was 40 degrees today in Michigan., Spring is in the air. Best wishes, Mike P.S. Glad you solved your problem, but too bad you messed up a valve!!! ![[Linked Image from i1321.photobucket.com]](http://i1321.photobucket.com/albums/u560/41chevymike/IMG_0396_zpsbc986a2d.jpg)
Posts: 604 |
Mike, you need to move south of that snow belts. 'Been 70 here today and looking for 75 Tuesday!
Mike, Now that right there was not so funny! "Sissy!" Give me a break! Nice try, though. Hope I ruined your supper. No valve problem that I can tell at this juncture. I'll check the tail pipe. Charlie BTW: Craftsman tools have been flying through a lot of flac here lately.  BTW2: It will be sunny and 75 here today. Wife is out of town visiting her relatives. I don't know whether to go to a bar and see heavenly Helen or work on the 41 coupe some more. Decisions, decisions. You who are still suffering from Canadian weather fronts, I feel for you. Do too!
Posts: 2,306 |
Hi Charlie,
It is 2:45 P.M. here. The snow continues to melt, an hour ago I was working on the rust behind my dash and my back went out. Like with you the wife is away. There will be hell to pay when she gets home. It is the second time in two weeks that I have had a problem. No more "Dream Garage" for a while. I'll just tell you the same thing my school principal used to tell the kids every Friday, "Its okay to be a little bit crazy just don't do anything stupid." The translation for you is it's okay to be a little bit crazy when your wife's not home just don't do anything stupid.
Have a great rest of the day, Mike
Well, found an old vacuum assembly. Extended the vacuum line, It seemed to work fine. Key word "seemed." Put the sucker on thinking that I could still save the new one for the project car, It didn' work. Had to go back to the NOS one. Mercy. Had a heck of a time getting the pin back in. Anyway, now it shifts just a little bit off. When it is shifted Reverse or Second the gear-shift liver kicks back a bit. About three-quarters (3/4) inch measured from the tip of the gear-shift lever. There was no such movement when installed the first time but in taking it off and putting it back on the trunction (that thing you can screw in and out) got a turn or two in one direction or another. Question for those who know about adjusting these things. As opposed to those who have taken them off. From what I've described about the movement, do you think I need to screw it in or out? Thanks, Charlie
Posts: 2,306 |
Hi Charlie,
For me it is only a guess??? I would assume it is easiest to turn something down by mistake, just the naturalness of gravity. So turn the thing up 2 turns and see if it corrects the problem??? If not turn it back 4 turns and check that response???
What do you think went wrong with the old vacuum assist??? I have two old units around that I thought someday I might rebuild/cleanup. What goes wrong with the unit other than bad vacuum rubber hose?
Good luck, Mike
Good suggestion. I'm guessing that turning it one way causes it to shift upwards on the gearshift and visa versa. I just thought someone may know which does what. Save me from having to get it wrong on one try. I'll sure as heck choose wrong. I think the internal boot just aged and didn't hold pressure as it should. Thanks, Charlie
Why are we not using the adjusting gauge?
What do you think went wrong with the old vacuum assist??? I have two old units around that I thought someday I might rebuild/cleanup. What goes wrong with the unit other than bad vacuum rubber hose? The canister must be disassembled, cleaned, lubricated and reassembled. Then properly adjusted. To all concerned. If the vacuum hose you use is stiff it will play havoc with the shifting. The hose must be vacuum hose, but also flexible.
Because: a. I don't have no stinkin' gauge. They cost way to much for such a simple washer-like tool. (Thanks, Ray, for having me admit that I don't have this essential tool.  ) b. I like crawling in and out from under the car so much that I would not like to be deprived of this great pleasure. c. Too thrifty, cheap or chinnsy(sp) (pick one) to buy a gauge. d. The shipping to took cost ratio is prohibitive. I was waiting until I had a big order so they could just throw it in the box. It don't weigh more than a nickel. Charlie
Posts: 3,136 |
I'd thought of "popping" out a few washer ( gauge's ) on my lathe ever since someone mentioned the size...But, alas I don't even have the "vacuum assist" any longer on my car...
How much postage could tossing a washer in an envelope cost...?
Posts: 1,743 Likes: 11
Posts: 1,743 Likes: 11 |
How much postage could tossing a washer in an envelope cost...? Christmas before last, you said you were going to make a bunch of these and send them out as "Christmas gifts". I waited until the following May and it never came. I knew it must had been lost in the mail. So....., then I ordered one from COT40's. Washer with instructions $8.00. Shipping $9.38. Are you kidding me. Yes, they are on the West coast and I am on the East, but.
Posts: 3,136 |
Well, heck...Sorry about that...Sometimes you have to keep reminding me...The shipping costs more than the part, my god...
Posts: 604 |
That happens far too often! We've all been victims of it.
I bought a mechanical pencil for $2.98. Cost to ship? $8.95 He said he hires all his shipping done and he has to make some money off that operation also???????
A word to the wise, if you are buying a few small items ask the vendor if they will ship them by first class mail. If so the cost will be minimal. Most automatically ship by UPS or FedEx that don't have lower small item package prices. It should be a no brainer for the vendors but that requires hired folks to make a decision to change the routine and possibly get chewed out from making a mistake.
I always try to consider the shipping cost on orders. Sometimes have to bite the bullet when need the item quickly and bundling items into a larger order not practical.
Chipper, Excellent point and suggestion. I will try it. Thanks, Charlie BTW: How is the adjusting gadget used, anyway?
Charlie, PM me your address and I'll drop it in the mail tomorrow. You can break it in for me. Every time I thought about trying it, I "somehow" talked myself out of it.
I will e-mail you the instruction sheets so you can study in your spare time. They are a "copy" and the pictures are about as clear as the repo shop manual pictures.
Russell, You have a PM. Thanks, Charlie
Wrapped and ready to go tomorrow.
Posts: 3,578 |
Charlie you may need to order parts after all,have you tried to attach the NOS boot yet?Mine was dry as a bone and replaced it before even intalling the cylinder.After getting your vac assist working properly the key will be to get the small rod adjusted properly,then fine tune with the larger rod..The problem I had with my old vacumm assit unit was air leaks,I use alot silicone and got a few more years out of it until I found a NOS unit
Mine was NOS right out of the box. As to the boot, it was shot. All cracked up. I just tore it off. I don't drive in the rain or on dirt roads all that much and, so, figured it would last at least half life. The old one didn't have a boot on it either. It was gone years ago. The 41 project will have a boot on it. I'll try hiring someone here on chatter who has the pleasure of installing a boot to do it for me. I figure "know how/been there, done that" is the key. I have some loose change around here somewhere. Charlie
