#302206 02/27/14 01:11 PM
langer Offline OP
Does anyone have a quick remedy for a sick sounding horn other than replacing it? It goes from sounding like a sick cow to a half sick cow to a sick cow that is trying to stand up. Occasionally it sounds as it should. I have cleaned the windings, the brass at the top of the armature is a bit worn. Anyone out there rebuild these items or do you just replace them? Looking for advice or a referral.
Erik Langhofer
Phoenix, Az.
langer #302221 02/27/14 05:10 PM
Not sure what type of horn your working on. You can try a Search of this site above sometimes it works.
Andys29 #302224 02/27/14 06:23 PM
langer Offline OP
Sorry. It is for a 29 Chevy, Claxon, 6v. ( I thought everybody should know that) :)
Erik Langhofer
Phoenix, Az.
langer #302239 02/27/14 09:41 PM
Hi Erik,
Take a look at this from a May 2012 post:
https://vccachat.org/ubbthreads.php/galleries/241856/Horn_Adjustment#comments
Happy Motoring,
Dan
DanR #302240 02/27/14 10:10 PM
langer Offline OP
Thanks Dan. Not sure that this is applicable to the 29 Klaxon but we will open it up again and take a look.
Erik Langhofer
Phoenix, Az.
langer #302244 02/27/14 10:45 PM
The horn on my '28 sounded sick recently, so I took it apart, cleaned up all electrical connections (including brush springs, and brush holders - all electrical connection points), and put a couple of drops of 3-In-1 oil on the motor bearings.
Sounds great now!
Rustoholic #302248 02/28/14 12:14 AM
langer Offline OP
Thanks Dean. I will do that. If I had to get up and work after nearly 50 years of not doing anything I'm not sure I would feel like doing anything either!! It has worked OK recently but not as well as it should.
Erik Langhofer
Phoenix, Az.
langer #302277 02/28/14 02:42 PM
If any of you guys have a similar Delco Remy instruction for the 1931 pancake horns, I would really appreciate seeing it.
knapp31 #302361 03/01/14 10:41 PM
I have a couple sick Klaxons and one really loud Montgomery Wards aftermarket replacement.
Anyone have a recording of what a strong Klaxon should sound like for a 1929?
bed
Jim Barnhart
Temple City, California
Link to Jim's Chevy
1929 Sedan
1969 Corvette Coupe
eldredjames #302381 03/02/14 11:09 AM
The sound of a properly tuned Klaxon is a combination of Edith Bunker screaming at Archie and fingernails across a black board. The problem with sick ones is generally lack of lubrication or wear (or both) between the motor shaft and bushings.
knapp31 #302384 03/02/14 11:14 AM
The vibrator horns that followed the motor driven horns are a completely different animal. Klaxon is a trade name. They made both types though most are referring to a motor driven "A,OOGa" type horn when they use the term Klaxon.
I don't know of a written instruction on the 1931 pancake horn. They were discussed in some detail a while ago in Chat. Maybe someone can take the time and effort to search for the thread so others can find it.
