#30182 08/29/06 03:15 PM
hello USA!
What color should the interior trim have,
if the color of the car is Brookhaven blue # 5504/219?
Could the color of the trim have been light Brown
as original trim of a cheva 1937 four door?
Or does anybody out there have a cölor map for
trim 1937?
Bengt From Sweden.
#30183 08/29/06 06:29 PM
The interior upholstery was available in only one color.It was a light brown...not a bright brown but more toward a browm/gray color.There were two different materials available for the Master DeLuxe.The most common was a mohair with a low nap.There was also an optional flat cloth in tan but was very unusual.
Hampton Coach sells an interior kit that has a color that is very close to the original.
#30184 08/29/06 07:36 PM
Are you referring to the color of the painted trim?
#30185 08/30/06 02:49 AM
Thanks for ansver.
I am refering to the color of the upholstery.
The color of the painted trim is brown so that
is no problem.
Thanks chevgene for a good ansver, I will try
Hampton coach.
Bengt From Sweden
