#296531 12/19/13 09:51 PM
Have start of re wooding a 27 Cabriolet coupe. What type of wood was used. Have a Fisher body service manual, but no where does it say what type of wood is used for pillar, header, or sill. Any info appreciated Ed
sqtubing #296535 12/19/13 10:40 PM
I think you will find that various hardwoods were used depending on the factory location. My 32 was built in Tarrytown N.Y. and had maple, poplar and ash in various places.
m006840 #296586 12/20/13 04:26 PM
After a lot of reading on the subject I decided that northern ash was an excellent wood to use for re-wooding my 35 chev roadster. I delibertately selected wood with dark parterns running thru it.
It cut nicely, by hand saw or preferably band saw. I was able to shave the wood with wood chisels and hand planers. It sanded nicely. It also planed easily to the thickness. I coated mine with Epifane varnish from Holland. its the preferred varnish of boat builders and considered the best. Its also about $50 a litre and the thinner is $18. Use quality naturel bristle brushes to apply.
mike Agrin
sqtubing #296716 12/22/13 05:35 AM
sqtubing: From what has been posted on this site in the past, it seems that what ever the local wood near the factory was used. Could have been ash, hockory, maple, pine etc.
Steve
SSG26K #301775 02/21/14 09:02 PM
just removed the lower rear wood from my 27 2dr 5 passenger coach that connects to the side sills behind the rear seats
i took a whole bunch of pictures and made some quick sketches if you think its the same and will help send me a PM with your emaill address
ron
its too large a file for email in Pdf format but i can mail you a disk with the pictures
