#301307 02/15/14 08:13 AM
minetto Offline OP
Where should the 6V connection for a signal light switch flasher be made on a 1941? Will the switched side of the ignition switch handle the load? If not, the hot side of the headlight switch looks to be very convenient. Thanks Mike
You could use the hot all the time on the headlight switch or to the down side of the amp meter. It should be hot all the time so you could use the flasher as a 4-way emergency signal.
Agrin devil
minetto Offline OP
I'll probably use the hot side of the headlight switch even though the Guide signal switch I am using doesn't have 4 way capability. Out of curiosity, I was wondering how much incremental load, if any, could be added to the switched side of the ignition switch? Also, does anyone know where the 1941 accessory signal switch was connected? Thanks again. Mike
I belive it was connected to the amp meter with an inline fuse
Al
