Received the manifold gaskets. Bit the bullet and injected windshield sealant under the rubber and created the mess of the century in the process.
Luckily, that cleans up quite well with varsol and about a thousand paper towels. There still is a bit of squeeze out here and there so I'll have to have another go at it. Today I was disgusted with the smell of the Varsol.
When I had done the woodgrain of the garnish moldings I had used the rear window molding from my sedan parts car. That ended up being way too narrow, so the upholsterer had installed it with a length of black hidem between it and the glass. It looked a bit like a thick rubber. I now have a proper coupe molding. Next step is to strip it and woosgrain it. Then I'll be able to install that neat little blind which goes in the back window.
I have 3 of those diecast 1.24 danbury mint roadsters, 1 green and 2 burgundy/maroon.
If you lift up the front seat the metal tray is under there with all the tools and the battery. Engine is fully detailed.
Underneathe you can see all the rivet detail and special ribs for the rumble seat floor system . I believe the 35 tech advisor mike Bancroft's roadster was the model for this.
I just put a scale duvall V style windshield on the green roadster off a 32 ford. Had to slice 1/8" out of the models top to get it to sit down properly.
About a year ago there was a '34 listed on ebay that was formerly owned by Wayne Taylor. The listing stated that it was used as the Danbury model. I'm not sure how accurate that story was… but I think this was the car.
But then again, I could be really wrong...
Wayne Taylor's car was a "put-to-gather". Too bad they elected to use it as a model. I have ridden in that car and also driven it.
What exactly does " put-to-gather " mean ??? " Too bad they elected to use it as a model " ???
What are you trying to say exactly.????????????????
Its not overly accessorized....as far as OPTIONS.....It only has rear spare with metal cover.........radiator ornament, bumper guards and right side tail light, twin horns, that I can see on the model.
I thought they used Mike Bancrofts VCCA tech advisors car a 35 roadster as the basis of the model. ?
Checked the moldings today, they were good and dry. So I applied the toner. It is a dark transparent wash that gives it warmth and bring the grain out. First picture is before, second after.
Here it is installed. Before everyone sends me back to the shop to redo it, let me assure you that it doesn't look blotchy like that in daylight. It is the flash which gives that effect.
Now for the blind, does the roller go in front or behind? It is not clear in the picture I have in front of it.
