#301158 02/12/14 07:33 PM
olgzr Offline OP
Help!!! I own a 1936 half tn pickup that I have restored and it's been so long I can't remember how the overload springs mount; Do they mount under the leaf springs or on top? Are they secured with the leaf spring U bolts or have a separate set? Anyone have any diagrams or ideas. Thanks so much for your help. olgzer
Olgzr,
You've got me there! My original equipment '36 pickup has no overload springs to my knowledge...just the 8-leaf springs it was born with. Here's a photo of the right rear. Are the overloads just extra leaves?
Wally
[Linked Image from i292.photobucket.com]
1936 Low Cab Pickup
Overloads usually go on top of the main springs with longer u-bolts, however I did not see overloads listed in my parts book for that model. Only as posted above an 8 leaf spring so perhaps it was a local add on. Also they should be in a position to contact a frame bracket. That should give some indication of where they mount.
There is a cast iron part that sets on top of the axle held in place by the extra long "U" bolts that hold the bottom leaf springs on. The overload springs are attached to the cast iron part on top of the axle by shorter "U" bolts. The overload springs rub (when in use) against rubber bumpers pads that are attached on the frame. These are at point of contact near end of spring area. I can send you an email attachment showing how mine are mounted.
I'm sure Olgzr would appreciate that-his email is listed on his profile.
olgzr Offline OP
Terrill,Thanks for your reply, I would appreciate an email from you showing how the overload springs are mounted. My email is ht51mrk@yahoo.com
hi there,
overload springs weather aftermarket or OEM are mounted on the top of the original spring so that the additional load is taken up gradually and distributed to the vehicle spring. I have a series on land-rover and many fit overload springs to gain extra loading capacity, that is how I know.....
http://www.stengelbros.com/Heavy-Duty-Leaf-Spring-Helper-Kits.htm
Peter
never give 100% unless you are giving blood.
I just removed the rear end from my 34 1/2 ton .The overload springs were on top of the axle and fastened by 2 long u bolts,
I have sent you pictures via email of the ones on my '36 truck. The rub pads are riveted to the frame.
