What does everyone do to prevent rust on parts that are unpainted? Im thinking about cast iron master cylinders, transmission cases and nuts and bolts specifically.
Do you clear coat them, oil constantly, or let them rust?
There are various conversion coatings that can be used. Most of them are use phosphoric acid in some form to give a protective surface. Then there are the oily coatings like LPS 3. Finally there are the primers and paints.
But how is the new looking, shiny cast iron look achieved? My plan is to wire wheel the transmission case, but it will not look new for long.
What is usually done for a correct restoration to keep the unpainted parts from rusting?
It seems like oiling every nut, bolt head and part would be too much maintenance and the oil would trap dirt.
As I have suggested in the past, the Eastwood Company sells a coating for exhaust manifolds that claims to keep them looking new...Should remove the scale but may be applied over light rust...usually done with the manifold still on the car...only $20 bucks a can...Check 'em out...Supposed to give the appearance of a freshly sand blasted surface...and stay that way to 1600 degrees...
Many of the early transmission cases were painted with a utility grade black enamel.
If my transmission were painted that would be helpful, but I see no evidence of paint anywhere on it...just an inch of dirt and gear oil. Its a muncie SM420 4speed on a 59 apache 36 if that helps.
do you all paint your transmission cases? What have you done with your bare metal parts on your restorations?
That calyx looks promising for exhaust.
Im thinking ill try some more clear paint until I find some better method.
Never had good long term luck with clear coating ferrous metals.
Former ChatMaster
ChatMaster - 5,000
Former ChatMaster
ChatMaster - 5,000
Yeh, I have to agree.. I've tried clear for a lot of years before I finally gave up on it.
Now I use Eastwood's paint to match the metal color.
If it's flat black, then I use spray-on Bar-B-Que paint.... that is rated for very high temps and it lasts a long time.
