Posts: 2 |
I HAVE A 1938 CHEVY MASTER DELUXE WITH THE ORIGINAL 216 CID MOTOR. DO I NEED TO ADD A LEAD ADDITIVE TO MY FUEL?
brsimplot
Posts: 3,008 Likes: 1
Posts: 3,008 Likes: 1 |
I don't think you need to add anything. I have been driving a 31 with the 194 CID engine for over 40 years. When they changed the fuel I didn't change anything on our car. I have had no problems.
Joined VCCA June 1, 1961
Posts: 762 |
https://vccachat.org/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=1;t=001060#000000
Posts: 348 |
The experts on this forum have convinced me that I should use Unleaded Regular Gas and 10W30 motor oil in my "41 Chevy. There has been a lot of discussion on both gas and oil. On unleaded gas the best argument is that the old ones didn't have leaded gas so why should you used it now. And on oil, the only reason they did not use multi-viscosity oil is because they did not have it years ago. JIM
Posts: 34 |
i have a 1948 stylemaster...does that need a fuel additive?
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
I am not sure when leaded fuel was first introduced here but since its demise I have not used any additive in any vehicle and not had any problems that can be attributed to the "lack of leaded fuel". My daily driver is a "leaded fuel" motor running lpg which has very similar burning characteristics to low octane unleaded petrol. Tony
"I have a 1948 stylemaster...does that need a fuel additive?" No! Your car will run just fine on regular unleaded gasoline.
The so called lead additives really do no good anyway.They are just a money maker (or waster).
IMHO chevgene is right they dont seem to do anything beneficial, only lighten your wallet. Tony
Posts: 4,951 |
I've burned unleaded fuel in everything from stock 54's with 235's to a 42 with the 216, to a 68 Impala convertible with a 327, 275 horse engine to a 55 pick-up with a 350 and a 41 Cadillac Five Passenger Coupe with a Chev 427 in it.
NO PROBLEMS that relate to unleaded fuel or NOT using lead additives.
I DID have trouble with the higher compression ratio of the 327 while using the 87 octane crap "they" call fuel. But it had nothing to do with "lead."
Bill.
The 327 engine would require premeium 93 octane if the timing is set correctly.
Posts: 11,162 |
We don't have added corn juice in Texas or Oklahoma (the places we have driven our 275 hp 327 Impala) and I can't see any difference in using the 87 or the 93 octane unleaded gas. No pinging. The timing and dwell is set to the shop manual specs.
Posts: 1,178 |
