Posts: 37 |
Looks like there is no avoiding it. I have to pull the head and unstick those valves. Anybody have a step by step for removing and replacing these valves including tools needed?
chevtrkmn
The valve seats in the head willl need to be "ground"....The exhaust valves should removed and ground also. 50% of Chevrolets could use a valve grind. A auto machine shop can do the job, just don't let them talk you into installing hardened seats.
Posts: 1,069 Likes: 9
Posts: 1,069 Likes: 9 |
Also make sure the shop you use. Knows the proper valve guide clearance from the valve stem.
Posts: 3,136 |
The valve seats in the head willl need to be "ground"....The exhaust valves should removed and ground also. 50% of Chevrolets could use a valve grind. A auto machine shop can do the job, just don't let them talk you into installing hardened seats. Hardened seats...Don't go there...Unless of course they'll throw in a bottle of "snake oil" with it...
Posts: 11,162 |
The best way is to follow the directions in the Chevrolet shop manual for your model year engine. You will need a valve spring compressor. and a screwdriver and a pair of pliers. first soak up the valve springs and stems in PB Blaster to free the valve springs, valve stems and keepers. compress each valve to take the tension off the split keepers and remove the keepers and release and remove the springs and any spacers. Keep track of where each valve spring and keepers and spacer goes. some times the valves will fall out of the head and othertimes the valves will have to be driven out of the head.
Posts: 3,136 |
Once the valve springs are off, you might want to pour a bit acetone around the stems...if the PB Blaster is not loosening them up...It's a good varnish remover...Depending on how bad things look you could always try using valve grinding compound...Depends on your budget...
Posts: 1,194 |
I have used spray carb cleaner for varnish on valve stems so I could get them out. It dissolves the varnish good, sometimes it takes a few sprays.
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
If the head has been removed oven cleaner works great on varnish and carbon.
