#299042 01/18/14 09:01 AM
Solan Offline OP
The Veteran gas station in Bergen
http://home.online.no/~herwitz/
is searching for help to identify two engines and 5 heads, and to find suitable parts (valves, etc.) for restoring the engines or swap/sell parts/complete engines asap.
Here are the numbers:
Engine # 1: Stamped # T 1540717 14 cast # 838710
Engine # 2: Stamped # 29713 - 8 CON - 1 cast # 836373
and engine heads:
(Only cast #s)
No 1) 24 836273 CON V 13 F - 201 1930 - 3
No 2) 8 K- 17 1. 836718 CON V 12
No 3 ) GM 838773 16 K - 1- 8 14 CON - 12
No 4 ) GM 3836650 CON V - 12 J 266
No 5 ) TOP 637878 P o 3 o 31 TRUCK
They also restore a 1937 truck, which will be converted to a wrecking truck.
Still missing some Grill parts:
1937 Grill Bottom Trim
1937 set of CLIPS - to hold side/bottom trim
Thanks for helping out!
carbana
Solan G, # 32797
Engine blocks
838710 is 1937-8 216 cu. in. block The "T" indicates a truck block.
836573 is a 1932 engine block (recheck number on block) Serial number is likely missing some digits.
Heads
836273 is a 1930-31 head
836718 a 1932 head
838773 a 37-8 head
3836650 didn't find
637878 didn't find on my lists.
I can' help on the parts.
Your head number 3836650 is probably 3836850 this is a truck 261 head.
check your other number 637878 you probably read it wrong.It probably 837--- ?
Solan Offline OP
Thanks, both of you. I will forward the information.
Hopefully they will find out about the missing details.
chevy
Solan G, # 32797
