Posts: 911 |
Has anyone used the gauge decals from F.S. and if so did it work good or bad? Roger
Posts: 911 |
Can a old shaky man (like you still do it?) Let alone me?
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
I refaced my gauges using the F/S kit and they came out fine. Doing the speedometer was the most challenging. All you need is lots of patience and a nice magnifying lamp.
Prior to refacing it might be a good idea to be sure the gauges are functioning properly. It's a real pain to have to remove the faceplate to transfer to another gauge.
Posts: 345 |
Also make sure you have the small bolts and nuts to remount the face plate to the gauge.
