#29823 06/14/06 07:11 AM
bigbth Offline OP
I've looked at the wiper tower and I don't see how removing the screw will cause washer fluid to be "sprayed" on the windshield. Was there a nozzle that was needed to get the water to "spray" up on the windshield?
Thanks,
Brian
#29824 06/14/06 12:10 PM
#29825 06/14/06 04:12 PM
Brain- I sent you some info-Gene
#29826 06/14/06 07:21 PM
bigbth Offline OP
Thanks guys! That's what I needed. Here are the directions Gene sent:
[Linked Image from ourworld.compuserve.com]
Once I figured out how the pump worked (and it took me longer than you might think), I knew there had to be something in those holes other than the screws. This means there are a lot of tubes running in and out of the car. Do you need to cut more holes for all the tubes?
Thanks again,
Brian
#29827 06/14/06 11:37 PM
#29828 06/14/06 11:46 PM
:confused: :confused: :confused:
#29829 06/15/06 12:43 AM
Yep, Me too
#29830 06/15/06 01:30 AM
#29831 06/15/06 07:09 AM
bigbth Offline OP
Is this some sort of Abbott and Costello routine?
#29832 06/15/06 09:01 AM
There is a grommet with 2 additional holes for the hoses,I believe its the spedo cable one.Check out chevs of the 40s,chef- chevy
#29833 06/15/06 10:26 AM
"Is this some sort of Abbott and Costello routine?"
Ask Macky Wacky.....he is the one that has the wacky postings. I was just curious as to why Macky Wacky made a posting above with no text. wink bigl
By the way, I found that the windshield wiper instructions that you posted are extremely useful and I have printed them out for future reference. Thanks for posting the instructions for all to see.
laugh laugh laugh
#29834 06/15/06 10:42 AM
JYD is just nosey!
#29835 06/15/06 02:00 PM
That is just the way old dawgs are, sniffing and sniffing around! (and I ain't gonna tell!)
#29836 06/15/06 05:16 PM
Here's another version of Gene's diagram with tubing lengths for 39 chev.
[Linked Image from ]
Is there a recommended location to mount the bottle?
#29837 06/15/06 05:23 PM
Again, here's another version of Gene's diagram with tubing lengths for 39 chev.
[Linked Image from www3.telus.net]
#29838 06/15/06 10:10 PM
bigbth Offline OP
The hole it shows the vacuum line from the manifold going through is located more like where they show the hoses from the bottle. There is no other hole on that side of a 38 car for the hoses to pass through the firewall. I would think that running the hoses down and through the speedometer cable grommet would not be an ideal solution.
What manufacturer is your installation instructions from, Mike? Is there any more information on the instructions? Do you have figure 2?
One problem I have is I ran the dual horn wires through that same hole. It's sort of full of stuff right now.
Brian
#29839 06/18/06 11:42 AM
The only other pic I have from an ebay auction is this one and I can't read it.
Anyone out there have a readable set of instructions for 38/39 that shows where to mount the bottle?
