#295561 12/07/13 04:17 PM
rjp Offline OP
Is the rumble seat cushion different on a 31 and 32? The new spring that I ordered does not fit. To big at the top. Or would any one have the measurements of one for the 31 thanks.
rjp #295566 12/07/13 05:02 PM
Is the rumble spring for a 1931 Coupe, Cabriolet or Roadster? The '31-'32 Coupe and Cabriolet should be the same. Roadsters will not be the same as the body sheet metal is different from the closed cars.
Chipper #295567 12/07/13 05:23 PM
rjp Offline OP
It was for a 31 roadster. The springs that I bought are too big. The base is ok but the top of the cushion is about 3" to long and about 2" to deep.
rjp #295570 12/07/13 05:33 PM
Did you initally order rumble seat springs for a 1931 roadster?
rjp Offline OP
Yep, but I did order from brand x. Snyders. They said they make springs for about every thing. I guess they did not say they would fit!!.
rjp #295595 12/07/13 10:40 PM
What did Snyder's say when you told them it didn't fit? I am sure they have sold more than one in the past and therefore should know if they fit for other customers. It also brings up the question Is there something different about your rumble lid that other '31 Roadsters?
rjp #295601 12/07/13 11:57 PM
Maybe they thought that you wanted rumble seat springs for a 1931 Ford Model A instead of a Chevrolet?
rjp Offline OP
Maybe on all the above, I bought all 4 springs and that is the only one that did not fit. Iam going to give them a call mon.
rjp #295627 12/08/13 12:14 PM
It is always best to contact the seller and/or shipper if there is a problem. Most reputable suppliers care about the quality and correctness of their products. We must understand that sometimes that is the best available. If they can't solve the problem then getting advise from others is warranted.
Chipper #297042 12/26/13 04:18 PM
Hey Roger!
My Uncle just found the same problem with his springs. I'm thinking that they are making the springs for a 32 roadster and calling them 31/32. Don't know. But last time I talked with my uncle he was going to send in his original spring and have them copy it. Let me know as he should be sending it soon.
Bruce
32 Confederate
Bruce S. DeFord
VCCA Judging Committee Chair
rjp #298093 01/07/14 10:24 PM
Hello gentlemen, happy new year!
I am also looking for the four seat/back spring assemblies for a 1932 cabriolet, could you publish contact info for where to find options?
Regards
Gerardo
Gerlealx #298121 01/08/14 07:12 AM
I might have the seat back for the rumble lid but I would need some measurements to be sure. It was marked 31/32...Joe
1931 Sedan Delivery 31570
1968 Z/28 Camaro
1969 SS 396 Camaro
