You didn't think you could get through the weekend without a question from the "weekend warrior", "wonderer".
I wonder which of these two bolt heads is correct for the fuel pump? There was one of each in the parts car, and who knows where my stash of originals went?????
![[Linked Image from i1027.photobucket.com]](http://i1027.photobucket.com/albums/y336/nonidrinkers/fuelpumpbolts.jpg)
Second thing I wonder is should I replace this shut off valve by the thermostat housing? And the second insert comes from the water pump.
I don't have access to an "accessories" manual and my car did not have heat originally. I notice in a past thread/post someone said they don't bother to shut off this line in the summer months anyway.
thoughts on which would be more correct????
As always thank you in advance for all your advice!
![[Linked Image from i1027.photobucket.com]](http://i1027.photobucket.com/albums/y336/nonidrinkers/heaterhoseconnectors.jpg)
Also it appears?? by some photos from my parts car that the passenger side of the heater valve line coming out of the firewall dumps back into the thermostat housing?
And I would guess that the driver's side of the valve goes to the rear of the heater box and then the front port of the heater box goes to the water pump??
Disregard the "t" and the other line running over to the head bolt heater FYI.
![[Linked Image from i1027.photobucket.com]](http://i1027.photobucket.com/albums/y336/nonidrinkers/HeaterVALVE.jpg)
![[Linked Image from i1027.photobucket.com]](http://i1027.photobucket.com/albums/y336/nonidrinkers/HEATERWATERpump.jpg)
