After the spindle nut and the outer bearing, reach through the access hole in the backing plate and, using a tool designed for that purpose or a flat tip screwdriver, turn the brake adjustment counterclockwise as you are looking at it from the front to rear or rear to front of the car. (The other way will tighten it.) This, of course, can be done before you take the nut or wheel off.
After doing that you may have to run a flat tip screwdriver in between the backing plate and the drum and gradually work it off.
In case the drum is stuck to the linings, you may have to sacrifice the linings and start using a hammer. Use the hammer as a last resort and start out by using a small one with the idea of helping loosen the linings from the drum. Keep working at it. Each time you use the screwdriver(s) you will likely break a section of the linings away from the drum. Eventually you will break them loose.
Also is it is stuck you may want to put the wheel back on and pull the car to break the drum loose. May not work though. I pulled a mustang until i wore through the tire and it blew. Had to break the drum apart with a big hammer and replace the drum with another one. Mercy!
Good luck,
Charlie
