Posts: 1,884 Likes: 12
Posts: 1,884 Likes: 12 |
On my 35 Standard Coupe there is a Tray that is 5" wide,50-1/2 long with a 5/8 lip that attaches to the back of the seat. Slides back and forth with the Seat. Does a 33 Master Coupe have the same Tray? My 33 has original Interior but there is no Tray there only some material. What about a 34 Master Coupe?
Jon T.
Posts: 956 |
This is what my 1933 coupe had too, with the metal piece riding on top of the wood.
Roger
Thanks, that's what I thought. Are the measurements the same as what me 35 is?
Jon T.
Posts: 3,163 |
Jon. I think it depends on the job number & the trim number. If you can post those, I can look them up...Joe
The Job No. on the 33 is 33-567. I don't see a Trim No. only K-7855. Hope this helps. jon t.
Jon T.
Posts: 3,163 |
Jon It was used on trim 25 & 26. You'll need to look at the tag real carefully as those stamps were stamped possibly after the tag was installed opposite of the job & body number...Joe
Jon T.
Posts: 3,163 |
Trim code 25 should've had that piece. The next step is to find someone who has a known original so you can get a measurement. Because it came trimmed from the factory it's not listed as untrimmed...but it might be the same as another car...Joe
A friend of mine who has a 33 has that piece in his car. It measures exactly the same as the one in my 35 so I can fabricate one. Now I need to know if 34 Master has the same piece.
Jon T.
Posts: 3,163 |
Get me a job number & a trim number & I'll check...Joe
Job No. is 34-567 and Trim No. is 38.
Jon T.
Posts: 3,163 |
Jon Yes, that one too should have it...Joe
Thanks Joe. Now I need two but if I don't find them I think I can make them.
Jon T.
Posts: 387 |
I have a 33 5 window with the original metal plate fastened to the back of the seat. I could get you some photos and measurements if you need them. Send me a PM if you have a need. Don East
I've had some of those Trays made and they are very good copies of the original. 35-36 Masters also had that piece but it is 1/2" longer. I could have those made also as they are the same otherwise. If anyone wants one they can send me a PM. thanks
Jon T.
