#297532 01/01/14 04:01 AM
Chevx2 Offline OP
Hi all, Happy New Year,
Can anyone confirm the type of thread used on the T piece that fits into the oil distribution fitting. The T piece screws into the top of the oil distribution fitting then one line goes to the oil pressure gauge and the other to the oil filter.
1/8 NPT seems to fit as does BSPT. Which thread is original.
Also The Brass compression fitting as supplied by the filling station RW717 1/8 pipe to 5/16 tube are the threads NPT or BSPT.
The reason for the question I'm looking at fitting a modern type oil filter and seem to have a couple of thread types on various fittings. I want to standardise so all the fittings are the same.
regards Peter.
Chevx2 #297721 01/03/14 01:56 AM
Peter,
The NPT threads are almost certainly original. British threads were very rarely seen in the USA in the 1920s.
The 1/8 NPT and 1/8 BSP threads can easily be distinguished from each other.
1/8 NPT 27 threads per inch, major diameter 0.405 inches
1/8 BSP 28 threads per inch, major diameter 0.383 inches
The American thread angle is 60 degrees, the British system uses 55 degrees.
Regards,
Frank.
franco #297936 01/05/14 07:35 PM
Chevx2 Offline OP
Thanks for the reply Frank I,ve used the NPT.
