#297161 12/28/13 06:31 AM
Davis38 Offline OP
Hey all,
I just want to double check with the experts here... My '38 is backfiring a lot lately, and anytime I turn the car to the right or make a sudden stop, she almost dies. If I turn to the left its fine. I am thinking I need to rebuild the carb, however, I would like the experts opinion here.
Thanks,
Davis
First check the ignition wiring and distributor. Look for a wire that moves toward a ground when turning or stopping. Also look over the spark plug wires carefully. At night with the lights off is another good time to check for voltage leak. Also check under dash for switch wire being loose or touching another wire or ground. Once you have ruled out electrical then look at carburetor. Moderate speed turns or stops should not cause a difference in performance unless the carburetor is loose on the manifold.
Is it back firing trough the exhaust or carburetor?
Along with the above, also check the float level in your carburetor and also your timing.
"After-Fire" = through exhaust ports, exhaust manifold, exhaust pipe, muffler and tailpipe
"Back-Fire" = through intake ports in head and out through intake manifold and carburetor and air filter.
UR welcome. Mercy! Agrin
Check the coil too.
VCCA #45194
Davis38 Offline OP
They were in fact backfires. However, it turned out to be the ignition wire shorting out. Glad I checked with everyone on here first, you guys never disappoint. Rewiring the electrolock tomorrow.
Thanks for all the help!
-Davis
Hi Davis,
Following is the previous discussion we had on rebuilding/repairing the electrolock on a 40's vintage car/truck. I am assuming they are about the same as on your 38?
1946 Chev 1/2 ton Ignition to coil wiring
Good luck, Mike
I reused these directions in the spring when I shorted out my wire because I didn't have the cap secured well to the top of the coil. Fortunately, I was only a block from home and two of my former high school students pushed me home. I was also turning a corner. Likewise, my engine miss fired, but also the wire insulation burned and smoked because I had previously rapped the fastener end in electrical tape. I had no problem identifying where my problem was!!! I'm just glad I didn't decide to touch it. It was extremely hot!!!
P.S. Reposted link to previous chat discussion.
That word, "Back fire" is often misused. It actually means blowing back through the carburetor. Through the exhaust it is called "muffler explosion". Two different problems.
what signature?
Sorry, I didn't see this when I posted.
what signature?
Back in the days of the manual spark advance, you could cause a loud muffler explosion.
what signature?
