Posts: 762 |
How do you get the cylinder out I did a search and I know you stick a stiff wire in the hole in the ignition and you are supposed to be able to turn the key counter clock wise to remove but it won't turn what am I doing wrong is there some other trick to removing this? I need to replace the wire to the electrolock mine is shorting out inside the cable.
Posts: 2,576 Likes: 2
Posts: 2,576 Likes: 2 |
you should be able to feel some spring tension as you push the stiff wire(staighten out a paper clip). as soon as you feel the spring tension, turn the key counterclockwise and release a little tension on your paper clip and finish the counterclockwise rotation, then pull cylinder with key towards you. good luck, mike
Posts: 762 |
I don't seem to feel any spring tension so I don't know if there is something goofy with mine or what but I also have an extra electrolock with no key but I don't seem to feel any spring tension on that either I know I need the key but I was just comparing the two and neither seem to have spring tension. Also if I do get it apart how hard is it to replace the wire?
Do you have a Genuine Chevrolet Eletrolock with the same key that fits the doors?Spray a little WD40 into the hole - it should get to the pin which may be stuck.Let it soak over night.
I usually use a bent paper clip to depress the pin.Cut off a paper clip and make it nice and straight.Stick in it the hole and give it a little tap.The pin may be stuck from not moving in the last 65 years.
Posts: 762 |
Yes I have the a genuine GM electrolock but now I guess I don't need the cylinder out as JYD has said I need to carfully split the two haves is there anything I should be aware of when opening this..Flying springs or anything? :eek: :eek:
Posts: 762 |
Oky doky I'll give er a try thanks JYD!
Posts: 762 |
Well I got it apart but how does that black plastic looking piece with the brass contacts come out I don't want to brake anything.Do I have to remove the armored cable from the back of switch? I see it has a hex head on it but don't know if I have to mess with that or not.
Thanks for the help :)
Posts: 762 |
Well I got it all put back together and works great also for future referance there is 3 indents on side of switch that also need to be pried out in order to get the plastic bakolite out of switch in order to solder a new wire on back.
Posts: 132 |
My cable wire is shorting too so I took my switch apart as well. I have been trying to pry out the 3 pinch points that hold the bakelite body but it means leveraging off the bakelite. Is that how you did it? It is wiggling but won't come out and I don't want to crack the bakelite.. Mike
Posts: 762 |
