#294500 11/22/13 07:12 PM
I'm in the process of restoring the engine compartment and I am looking for the proper color for the valve cover. Currently it is black, but I believe that it is supposed to be blue. If it is, does anyone know where I can purchase the proper shade? Thanks for your time.
When it stops being fun, I don't want to do it anymore.
1942 Pickup
1949 Deluxe Sedan
1990 Lumina Coupe
The engine should be dark blue-gray and you can get the correct color from the Filling Station. www.fillingstation.com
Thanks. Appreciate it.
1942 Pickup
1949 Deluxe Sedan
1990 Lumina Coupe
You bet and good luck with your project.
How about the color for the 51 fleetline? I just got my engine back from the machine shop.
I think chev gene had a post telling all the parts that were painted on the engine.
Water pump, manifold,
What else?
"Frame Off" restoration, its a journey not a destination
The engine was dark blue-gray.
The complete engine, minus the accessories like the starter, generator, carburetor, distributor and etc. was painted as a unit at the factory.
All 1929-1952 PASSENGER CAR AND TRUCK engines were the dark blue/gray color.
1953 car engine (with standard transmission) were the same gray/blue.
1953-1962 1/2, 3/4 1 and 1 1/2 ton truck engines were blue gray including 8 cylinder models.
1953 Power Glide and all 1954-1962 car engines were blue.
How about the breather tube, dip stick, oil cap
Paint them too?
Any body got the correct engine compartment color photo? 51 fleetline pG
I believe the tube and caps were black, but don't quote me. Junkyard Dog and Chevgene are more knowledgeable.
Double check your engine number to make sure it is actually a 1949.
National Chevy and Chevs of the forties have the paint you need.
Rick
Filling station guy said the breather tube and dip were painted engine color
Didn't think to ask about the cap?
The breather tube was black. The dip stick was not painted. The oil filler cap on the valve cover was in place when the engine was painted so it was gray....The area on the valve over that it contacted was then unpainted due to the cap being installed. often see them unpainted but this is correct. Would have been unpainted iif you purchased a new one through the parts dept.
What color was the dip stick then?
I'm guess the shaft tube was painted engine color?
As stated above:
The dip stick tube was installed before the engine was painted so it was gray.
I laying out all the parts that need painting.
What about the fuel pump?
Not painted
