Posts: 1,866 |
Anyone use National Chevy Association lately for a complete upholstery job on a '49 chev or around that year? Header, panel, seats, ect.
Posts: 1,866 |
Should of added, "Just for the material only."
Posts: 3,801 Likes: 1
Posts: 3,801 Likes: 1 |
A friend purchased the upholstery set from NCA for his 1951 Chevy.
The appearance of the upholstery reminded me of the square type pattern seen on a mid 50's "Del Ray".
Upholstery fit well, certainly not original in appearance, but OK for the money spent, if "stock appearance" is not a concern.
Posts: 1,866 |
Thanks bobg1951chevy. It does not have to be the exact color, just so the fit is OK so this helps. I only live about 130 miles from a store in St. Paul, Mn and will stop by their store when I'm down there. Did he get the vinyl or cloth? There is also an Amish shop in the country here and he said he might be able to do it. A friend had one done there very reasonable.
Color AND pattern were not the same as factory.
His upholstery is the cloth.
Again, the fit is good, no loose or sloppy fit.
I may have a pic, will look.
Posts: 1,866 |
I did find a pic, BUT the pic is taken from outside of vehicle. Only the very top of the front seat back is visible. Not much help, but if you would like this pic, I will send it to your email address.
Posts: 1,866 |
Thanks Bob, I'll go check at Nat'l Chevy and see what they got. Appreciate your reply's. How it fit was most important.
Posts: 410 |
Where do I find carpet for my 51 hardtop ? How is National chevy for carpet ?
easymoney
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
Posts: 292 |
I used ciadellainteriors for all the interior of my 53 it was excellent in all ways, fit, finish and 100% all parts needed to compleat and equal to Hampton coach and half the cost. Al
I used ciadellainteriors for all the interior of my 53 it was excellent in all ways, fit, finish and 100% all parts needed to compleat and equal to Hampton coach and half the cost. Al Didn't Peter Ciadella pass away recently?
Thanks Bob, I'll go check at Nat'l Chevy and see what they got. Appreciate your reply's. How it fit was most important. Yes, the fit was very good, not "baggy".
Yes, Pete did pass away. The company continues.
Posts: 292 |
For got to mention we got the 53 upholstery this summer Al
Posts: 1,866 |
Looks like they don't make the '49 upholstery.
Posts: 1,069 Likes: 9
Posts: 1,069 Likes: 9 |
Call and ask them. They may be working on it.
They recently added 49 to 53, I believe. Call.
Posts: 1,866 |
