#294230 11/17/13 07:26 PM
ron1967 Offline OP
working on a 1929 chevy landau convertible at the Forney Transportation Museum here in Denver
while cleaning and wire brushing the under side of the running boards i found a Canada patient stamp
1660307, 308. how do you look up Canadian patients, not sure if is for the sheet metal portion or the covering which looks glued/bonded to the upper surface
thanks. ron
Ron, is the car Canadian built? Have you added your body tag info to the list we have going here?
Ron: For our Convertible Landau research project we need the Job Number, the Body Number, the Car Serial Number, the Engine Serial Number, the Block Casting Number and the Block Casting Date.
Thanks!!
