#294195 11/17/13 03:07 AM
n2chev Offline OP
I have tried using search without much luck. I need to polarize my generator on a 48. I have always thought it was using a jumper wire momentarily from Bat to Ground, My regulator is wired ( left to right) Bat-Arm-Fld.???
hoppy
"Four-Doors-Forever"
With the voltage regulator wire connections made up, momentarily jumper from "BAT" to "GEN" or "BAT" to "ARM", depending on how your regulator is labeled. Looking at the regulator head-on, the left terminal is "BAT", and the middle terminal is "GEN" or "ARM".
Mark
I think that the information is also in your shop manual.
n2chev Offline OP
Thank You Mark
hoppy
