Hello,
i am Tino from Germany. I own a 4 door 1937 sedan. Simply a master, but with some nice goodies. Radio, electric clock, heater and 12V electric.
I have some questions about the electric clock.
The working principle ist that the magnet coil (1) pulls up the weight(2).
Due to gravity the weight pushes a gear wheel (3) and keeps the clock gear runing.
But also a little seperate mechanism (4) with electrical contacts (5).
When the contacts are closed the magnet is on and pulls up the weight again.
The contacts will be opened immediately when the weight is pulled up.
The contact is only for split second.
I tried this with a little 6V toy battery (6=plus terminal magnet coil ). When the battery ist near empty the magnet has not enough power to pull up the weight to lock into the gear wheel. So the weight falls directly down closes the contacts again an the hole system starts to shimmy.
How powerfull must a step down converter (12V->6V) be? How many amps? The magnet coil resistor is about 3Ohms.
I have only a cheap multimeter. Not good enough for messuring of amp peaking when contacts are closing.
Is a step down converter nessecary at all? Cause only a pulse is needed for the magnet and no resistors or circuits are there.
Surely i would feel better with a step down converter right now.
Tino
![[Linked Image from s22.postimg.org]](http://s22.postimg.org/5mxvujex9/DSCN1148.jpg)
