#293770 11/12/13 03:10 AM
Joe55 Offline OP
Is there anyone that lives in Sacramento. I would like a mentor but a simple buddy with the same type of truck will do to compare and learn as i finish my truck. Let me know if you are out there I would like to get in contact with you.
If you scroll down more, you will find a truck forum. That forum may also be able to assist with the fender skirts.
Hi Joe,
If you're a VCCA member, you can go to the member roster, plug in Sacramento, CA and do a member search.
Good luck. Another good reason to join if you're not.
Rick
